Before you get started, you will need a FAT32-formatted MicroSD card. We recommend using at least a 16 Gigabyte card.
If you need to format the card, you can use the SD Formatter for Windows and for macOS. On Linux you can use gparted or parted.
Download the OSMC Installer (available for Windows, macOS and Linux).
After the write process to the SD card has finished, you can unmount the card. Connect your Raspberry Pi to a screen and keyboard, insert the SD Card and connect the power supply to boot the device.
Now the base system will be installed, this will take a few minutes. Once finished you should see the OSMC main menu as displayed on the left.
After the first ssh login, the APT cache will automatically update. Once done, type in the following command to install the PPTP client:
sudo apt-get install pptp-linux
When the installation is done, create a PPTP configuration for the server location you want to use. In this example we are creating a configuration for chicago.perfect-privacy.com by editing the following file:
sudo vi /etc/ppp/peers/chicago
Copy the following content into the editor. You will need to change $USERNAME and $PASSWORD for your Perfect Privacy username and password.
pty "pptp chicago.perfect-privacy.com --nolaunchpppd --debug" name $USERNAME password $PASSWORD remotename PPTP require-mppe-128 require-mschap-v2 refuse-eap refuse-pap refuse-chap refuse-mschap noauth debug persist maxfail 0 defaultroute replacedefaultroute usepeerdns
Now start the connection by typing:
sudo pon chicago
You can traceroute google.com (or any other host) to make sure that your traffic is actually routed over Chicago.
To automatically connect to the PPTP VPN after startup, create an init.d script as shown below. You can give it any name, in this case we call it “pptpvpn“.
sudo vi /etc/init.d/pptpvpn
#! /bin/sh
case "$1" in
start)
pon chicago
echo "PPTP Started"
stop)
poff chicago
echo "PPTP Stopped."
echo "Usage: /etc/init.d/blah {start|stop}"
exit 1
esac exit 0 To start the VPN client on boot, issue the following commands:
sudo chmod +x /etc/init.d/pptpvpn
sudo update-rc.d pptpvpn defaults
If you have any questions, comments or other feedback regarding this tutorial, please use the corresponding thread in our community forums.
